still doesnt answer if the clutch will work.
The 6.0 & 7.3 SD fans look the same but are not. Diff clutch mounting. The guys that have tried the SD 7.3 fan and clutch have had trouble with it clearing the radiator. The arm on the clutch that mounts to the water pump is just too long.
I have a 6.0 fan mounted on the obs clutch and its perfect. Unfortunately I don't have any comparison data but I like it.
