7.3 forged engine, aftermarket parts
truckpullin_75
Olney, IL
I have a forged rod 7.3 engine that has H11 head studs, valve springs, 3/8 pushrods, and aftermarket plenums. Work was done by Swamps. Block originally came out of a 97 I believe and I bought it out of a 2001 F250, in which it was used to replace a pmr engine. I do not have compression numbers as of now but I have seen the engine run and rode in the truck it came out of, for what its worth. Bought this engine to put in a daily driver project I plan to build but had a change of plans. It was running 300/200 Swamps injectors, Gen 3, and a BFH turbo. There is no turbo, pedastal, hpop, or injectors with the engine right now but I do have stock parts from a 2002 with 98k that can be installed if desired. Not sure what to ask but since I have to put a price I'll say $3000 but I'm open to offers. Engine is located in southeastern IL.
truckpullin_75
Olney, IL
Don't have any way to get compression numbers at the present time, there are no injectors in the engine so I would have to come up with a set to test it. I did ride in the truck the engine came out of and it had only normal blowby out of the oil fill cap. The injector cups look as though they were replaced as well but I can't verify that. Here are some pictured of the engine and under the valve covers.
truckpullin_75
Olney, IL
I am working on getting a compression tester. I would also consider a partial trade for a good 4r100 and converter for a 7.3 4x4. If somebody has a bts or a jw I'll throw in cash on my end.
