7.3 heads- reman
Derek@Vision Diesel
Canby, OR
Set of 7.3 heads for sale.
These have been Mag'd, pressure tested, surfaced, new valve stem seals, fresh valve grind, new bronze guides installed.
Heads are literally perfect and ready to be installed. Would consider these to be of even higher quality than a head you can buy straight from ford.
$1500 shipped for the pair, no core required
vr6nutt
SoCal
All new valves/springs? How about the seats? Are they original? I have a new set of valves and Comp 910 springs/shims waiting to go into cores - but cant seem to find any with crack-free seats.
Derek@Vision Diesel
Canby, OR
These were sent to the machine shop for magnafluxing, pressure testing, surfacing, hot tanking, and at that time the valve guides were checked. If any were out of spec then they were diamond honed and bronze guides were installed. Brand new valve stem seals. And the valves have a fresh grind.
The valve springs and valves are not new, but they are thoroughly inspected.
