7.3 high performance parts
pontiacross
well I have had my pulling truck for sale because I want to start putting together a mechanical 7.3 for the 3.0 class. anyway I wanted to keep it in one piece incase It didn't sell I was going to pull it again this year. However my wife and I are in the process of buying a house that needs some remodeling and it dosent look like I'll have time to do any pulling this summer, so I am going to part it out, if no one wants the rolling chasse I'll build the next one with it.
all prices are OBO
Swamps 450cc 400% injectors with about 6 hooks on them since swamps went through them and installed the 400 nozzles - $2300 no cores needed
Swamps BFH turbo 80/88 comes with 80 and 66mm covers - $1,100
74mm clipped wheel with a 74mm and 66mm cover for BFH or s400 turbo - $300
Homemade T4i turbo mount for OBS trucks not real pretty but works good - $500
BTS dual HPOP setup - $1000
South bend 3,600 dual disk clutch with iron disks only 5 or 6 hooks on it - $1,400
air to water cooler setup with pump and tank - $600
aluminum tanked factor intercooler - $200
complete fuel system from tank to engine using an aeromotive pump and regulator and seeds the back of the heads through the banjo bolts - $500
4 position ts chip - $200
97 7.3 engine that came out of a wrecked truck with 220k ran good until wrecked should still be fine. no injectors, turbo, or HPOP - $850
96 or 97 7.3 engine that needs to be overhauled, no HPOP injectors or turbo. I know very little about it other than it has low compression, picked it up as a spare - $400
96 f350 reguar cab regular cab 5 speed rolling chassie. dana 80 rear dana 60 front 5.13 gears with welded diffs. comes with factory trans and transfer, pulling hitch, weight rack, traction bars exc. - $4,000
I'm happy to ship the smaller stuff but if you want a ngine or something like that shipped we'll have to talk about it.
Truck is still in one piece so It may take me a couple days to get what you need pulled out.
Thanks
Ross
Motostroker
I really want that rolling chassis. I'm coming up to Indiana in two weeks. Can you call me? 8034802944
pontiacross
sorry if I haven't responded to some of you yet but the weather hasn't been very good the last couple of days so I haven't been able to work on the truck and my internet has been sketchy at best. I did have time to work on it to day and should have the engine out and most of it stripped down tomorrow. then I will start getting with everyone.
blk99
I will take the fuel system if the sale falls threw.... money in hand
pontiacross
fuel system is gone
I took a few pictures tonight but still need to get some more
the clutch dosent even look to be completely broken in yet
I am in need of a good single disk clutch and flywheel for my tow rig if anyone has one they want to trade I may be interested
there are 2 flex couplings under the heat wrap
I forgot to get pictures of the IC pipes and intake that will come with the mount but I will get them
pontiacross
the last of the turbo mount pictures
the ic pipes may have to be modified for your application
