C'roy78stroker
I removed an injector from the higher milage engine of the 2 that i have purchased recently and tore it apart. I checked the solenoid and it tested good (3.0) The poppet did not have any damage/wear. Is this a common thing not to see wear at the poppet? I then removed the nozzle holder from the body, and checked everything. The only thing that jumped out at me was a little discoloration on the fuel side of the plunger. I didnt see any vertical scoring of any kind. Id like to know if there are any "problem areas" i could check, and get an idea if i have a decent used injector or one that will need some work. Any input would be appreciated.
Thanks Cory
Thanks Cory
