7.3 intermittent miss
FL
Posting for a buddy,
Truck is a 1997 7.3 cclb. It developed a miss right after a chip was installed. The chip was removed and made no difference with the Miss. it happens at all temps and has no white / blue smoke.
Parts replaced-
New ford cps
Ford uvch
New rosewood 160/30 injectors
Swapped pcm & idm with known good one
Swapped ipr with a good one and replaced wiring
E fuel installed
He says it seems to miss worse when cold. There's no codes when I scanned it with my AE. Icp has no oil in it and icp% & ipr D.C. Are fine.
Any ideas where to look next?
jpow95
What's the fuel pressure I had one where after 200cc injector install we was sucking air and not getting volume of fuel needed just throwing that out there
FL
He checked and it's 65 psi. He also replaced both fuel tanks and replaced the puck up tubes. It has the same issue with the stock fuel system.
