nasty6.6
Hey guys something is up with the old 7.3. Truck will run fine one minute and then act up out of the blue for a while then will be ok. It has no power at all when it acts up, running down the highway @ 70 it will just start slowing down and you can give it gas and nothing, no smoke and you can hear the turbo pitch change when trying to give if fuel and rpmsstay constent so clutch isnt slipping... down shift and rpms jump up truck still slows and wont accelerate this will continue until stopped. Then it will be fine for a whille and then will act up again.
edge tuner
38r with ww2
stock inj and hpop 245xxx miles and icp sensor does have a small leak/seep not oil dripping out; hpx crossover is leaking new line on order.
I have read a bunch of threads about similar issues but nothing like this. or they say throw a set of 250/100s at it with a new hpop and see what happens... but any help is appreciated!
edge tuner
38r with ww2
