RiVerBum01
Having some problems with my truck the past few day. Maybe you guys can help me avoid a shop bill. I'll start from the top.
5 days ago it was around -1 when I got off work. Truck barley would turn over enough to crank, but it did on first try. Coming home from work and my heater would act up. Would blow hot for one min then cold for a little bit then hot again. Had a little coolant smell so I figured heater core. Popped the hood and the degas bottle was empty. Filled it up and heard water poring from somewhere. That's when I discovered the water pump took a crap on me, constant streem of water poring out. Plugged it up and fast forward 3 days.
Filled the degas bottle up to drive to my fathers 2 miles away to work in the water pump. Went to start the truck and nothing. I've checked a few things already, just hoping maybe you gues could help point me in the direction of something I may have missed.
Unplugged the icp sensor, checked fuses, and checked oil level and still not starting. Getting a wts light, also the tach moves along with the oil psi gauge. Batteries are 3 months old. Anything else I can check Before I put it on te trailer? Any help is greatly appreciated
