silverpsd_06
Have a 96 powerstroke that will not start, have replaced IDM with a known good one, new cps, new fuel pump also. Got it hooked to a solus today to monitor ICP and IPR duty cycle, ICP stays at a 170 psi for the first 6-7 seconds of cranking and then maxes out to 2464.7 and doesn't budge. IPR duty cycle starts at 15% then hits 55% and hangs there. Solenoid was loose on the IPR so I tightened the tin nut to see if that helps to no avail.
I'm leaning toward a bad IPR or a hpo leak of some sorts has anyone ran into this situation before? Any advice would be appreciated!
