7.3 powerstroke exhaust manifold bolts
Blue 7.3
Bay Area, California
Hello all,
I am currently rebuilding the top end of my 1997 f250 7.3 powerstroke. I have came across a puzzling issue and so I have enlisted here in the Powerstroke Army to see if ya'll can help. So, the exhaust manifold bolts I ordered, which is OEM Ford part number F4TZ-9 S425-A, they DO NOT fit my heads! They simply are too big for the bore, on both heads. So the only logical conclusion is that there is another part number I need? But my internet searches have been fruitless. Does anyone know another part number the 1997 heads need? Any info would be great, thanks in advance!
Lt.Dan
Visalia, CA
I'm pretty sure all the 7.3 powerstrokes (94-03) used the same exhaust manifold bolts. I've used the same kit for my 96 and 02, dunno why 97 would be any different. Maybe just drill and retap to the correct size? Seems a bigger bolt would be better anyways.
ghohouston
Lewisville,Texas
Do you already have the old manifold bolts out, and trying to install the new ones? The manifolds "warp" and become untrue to the head, making it seem like they wont fit.
Blue 7.3
Yes, the old bolts are out. When I hold the old ones and new ones side by side, the size difference is obvious. I don't understand why. Are there maybe two types of bolts Ford used?
Lt.Dan
Visalia, CA
What is the actual thread that came out vs what you got? If I remember correctly they are supposed to be 10mmx1.5.
