I've been having an annoying rattle for the past 10K miles and it's not getting any better. I can't really find the problem but I can tell you what I see so far. The rattle only happens after the truck has been running for 10 minutes and all the way up to full temp. It only does the rattle at idle (stopped) sometimes, if you roll the throttle stopped it will do it but will go away after a couple minutes and 5 mph or less and does it in park, reverse, N, drive, and I'm sure 2 and 1. It can also be felt in the cab. The rattle noise is coming from the exhaust but the exhaust is clear of everything. It sounds like it's making its way through the engine into the exhaust. Uppipes are tight and not leaking and all bolts are good on the exhaust manifolds. Transmission feels the same as it always has. Anyone have any ideas on what it could be? Truck is a stock 02 F250 2wd with 148K and a 4" mbrp TB exhaust.
