7.3 SD Parts
Cota
Cleaning out the garage since I don't have the 7.3 anymore.
All prices do not include shipping.
If there is no price on something it's make offer.
I can text pictures if your interested in something.
7.3 crank, make offer
7.3 core heads, make offer
Valve cover gaskets with injectors harness, 2 sets, $40 each set
7.3 HPOP lines, 2 sets, $40 per set
Complete engine harness with starter, glow plug and AIH relays and mounting brackets, $150
New stock low pressure oil pump, $30
AIH and wiring, make offer
Stock fuel filter lid, make offer
Stock fuel filter lid and filter housing with fittings for a regulated return setup, $40
Stock fuel pumps, 2ea with mounting brackets, $50 ea
Stock turbo pedistall, $40
Stock driving/ fog lights with mounting brackets, $30
Plastic clips that hold the heater lines above the valve cover, make offer
Stock waste gate actuator, make offer
4r100 inspection cover, make offer
Up pipes and flanges, make offer
Up pipe collector and flanges, one drilled for EGT probe, 3ea, make offer
Driver side battery box cover, make offer
Air intake hose and CCV connector, make offer
Stock thermostats, 2ea, make offer
Exhaust back pressure sensor, tube, fittings and HOPO gear cover, make offer
Engine lift brackets, make offer
Stock balancer, make offer
Rear main seal kit, make offer
Rear engine cover, make offer
Oil fill tube, make offer
Dip stick tube and dip stick, make offer
Water temp sensor, make offer
Top radiator hose and clamps, make offer
Piston cooling jets, make offer
Stock pistons, used just long enough to break in a new Ford remanned motor,
You will need a ring set, make offer
Cam gears, make offer,
Thanks
