7.3 standalone harness?
weigelra
2001 7.3 2wd swap into 86 IDI 4x4 truck
Hi guys,
I have both trucks side by side and want to swap the 2001 into the 86.
Are there stand alone harnesses or ECUs available. Or do you recommend use everything form the 2001. Don't want to use the cluster.
Anybody in LA with experience?
Thanks a lot
Hi guys,
Thanks a lot
Everything from the 2001 needs to be swapped.
Flatheadvff
Earth
trying to run a 95 powerstroke on a engine test stand. Have a rollover donor pickup, so have a complete harness and ecm, and idm. Have been told there are only a couple of wires you need to hook up to idm to make run (a long time ago, have retired from mechanicing professionally just about as long ago). Is this true and does anyone know which wires I need? Have motor out of pickup and is boocoo work to install, so want to be sure it runs before installing. Have three engines I'm intending to do this with, two are engine swaps to two deuce and a half...one manual, one e4od. I know I'll need full harness for swap, question is just to run on engine test stand.
