7.3 Super Duty with Zero Off Idle Torque
Arisley
Arlington, Texas
OK, you know those little fittings between the fuel line and the head. Those are not just fittings, they are one way valves with super fine screens in there. Remove those, bore them out smooth with a drill bit, clean them out rally well (any tiny shrapnel left in there has to go through an injector to exit the motor). Put it back together and I bet your issue goes away. I know it sounds crazy, but exact same issue on my truck (automatic though) and on a friends truck (his was a standard). He had been chasing the issue for over a month, and he was a top notch mechanic.
Petro
Lincoln Nebraska
Hmm that's interesting. It doesn't really seem to be starved on the top end but I'll check those out. I'll report back.
houston88
Remove the one way valves or just clean them up really well?
Sent from my iPhone using Tapatalk Pro
