BBottoms
I've got a 7.3L sitting in my shop that I need to get rid of. I had bought it to slowly rebuild for my 95, but have since been converted to a 6.4 junkie and will be selling my 7.3 soon. It has a 7/96 build date and is complete minus injectors, turbo, dip stick, fuel pressure regulator and crank sensor.
I purchased this locally from craigslist as a core and know nothing about the history, mileage, etc. It didn't have injectors and I don't have any laying around so I have no way of checking compression or doing a leak down test. It does turn freely and easily and pumps air, so nothing major mechanical wrong. Oil Pan appears to be in okay condition and no milky or nasty oil. It was nice and clean under the valve covers so it's been at least decently taken care of. I haven't pulled the heads should someone want to give it a shot running as is or do a compression test. However, if I have someone that is seriously interested I can pull the heads and check out the cylinders.
Located 10 miles from Hodgenville, KY. $500 OBO
