OBS F350
So, what to check on this one last time.
traction control can kick on if trans is slipping?
I honestly don't think it would, I could be completely off here but on semi's with traction control they go off of the abs sensors on the wheels to detect slippage and corrects itself when it senses it. Where is the speed sensor located on these trucks? Every speed sensor I've messed with is after the trans, like on semis they are on the output on the transmission, so if the trans slips it's not going to detect an increase in speed like if your wheels were actually slipping and increasing speed drastically. I have not messed a whole lot with traction control issues other than most of the time its a broken ABS sensor or funky speed sensor.
If your speed sensor is after the trans there is no way I could see a slipping transmission causing traction control issues.
