***911****911***
Snake
Flo Rida
I just wanted to thank you G racing. Also wanted to let everybody know we have a scangauge 2 hooked up to the truck but i never added any gauges to the x gauge except trans temp because after reading i found out that you dont get good HPOP reading if the truck is tuned for some reason. I dont know if the scangauge will help but we do have it hooked up to the truck. And thank you guys very much. I dont know if she will be able to put the ICP in or not but im sure she can do it with a good explination of what to do. She has acces to all the tools a man could want. (im a heavy equipment mech by trade and in the navy)
True. ICP readings are usually 30-50% of actual if your truck has a tune on it. It's one of the programming "tricks." The numbers will look normal once the tune is taken out (assuming an otherwise healthy truck).
