96' 7.3 short block
fordornothing
Guernsey, WY
I have a 7.3 out of a 96 f350. Had 173,xxx when pulled. No fuel system, Turbo has minor shaft play, No water pump, I have a wiring harness to go with if needed. It did run when pulled but I believe a wrist pin locked up due to aluminum in the oil. I can't remember if I have injectors in it or not. Make offer
I also have a 7.3 short block out of a 95 that I might be willing to sell. Unknown mileage, unknown running condition. Any thing plastic is gone including injector solenoids. And VCG/ UVCH/ engine harness. Parts were used as a donor for a burn truck.
Make offer
Engines are located in Golden, CO 80403
jrm1982
Could you give me a call tmr sometime 9705185986 thanks name is jeremy
