earlybroncoboy
Also I replaces uvch on both sides but I used Dorman, truck had miss before and after. Maybe mis-shielded wires? Anyone had this problem?
Did u replace plug going into harness? Soldered wires good shrink wrap? And yes a cylinder low compression should cause rough conditions all the not randomly.
Just to clear things up I was meaning to do a comp check to see if was worth spending money on injectors not necessarily to diagnose ur issue.
Sent from my SCH-I535 using Tapatalk
