I recently purchased a 96 7.3. I'm lookin to put 37x13.50x22 toyo Mts on it. It's currently leveled. Any idea of what lift I'd need to clear leaf springs and not rub?and anything else I would need.
Stroker, is there a difference in the number of leafs per front pack between the 250 and 350 lifts?
Got a lift here I'm trying to figure out if it's for a 250 or 350.
We have what needed to get the best possible ride quality. Our RS kit-SD spring swap will get you clearance for 35". Adding SD lift springs will get you the needed clearance. Because the suspension will actually flex unlike non SD lifts, 7-8" is recommended. Been doing these since we first developed this mod in '99.
