Luke@MillerPerformance
Got a 97 7.3 that keeps killing Cam Sensors. All OE Ford Grey sensors. Throw one in, runs perfect for 10-15 minutes then nothing, won't even try to start, throws P0341 and P0344. Every sensor that comes out has a spot that's completely wiped clean, like the gear is hitting it. And some of the sensors look like the gear is rubbing on them once the oil is wiped off.
I'm assuming there's some sort of thrust plate to keep the cam located in the block, anyone seen something like this? Truck is a manual with 160/80 injectors and the owner loves to rev it out.
