97 Powerstroke Engine and Parts
under construction
Jamestown, OH
I have a complete 1997 engine with 209,00 mile on it that was running when it was removed for sale. It has a few sensors missing that i have removed and used on other things. There is no wiring harness because that has already been sold. The turbo and up pipe were remove along with the injectors but I still have both. I also have the alternator and ac compressor. I would sell things separate or all together. I also have a spare 15* HPOP and a brand new set of Comp 910 valve springs and shims. I would prefer local pickup due to not having a pay pal account that is linked to my bank account but shipping can be discussed for the small items if need be.
Prices are as follows:
Complete motor with injectors, turbo, HPOP and all accessories - $1,300.00
Complete motor without injectors, turbo, HPOP, and accessories - $800.00
Trubo - $250.00
Injectors - $300.00
Alternator - $50.00
AC Compressor - $75.00
Comp 910 Valve Springs with shims & valve spring height micrometer - $100
15* HPOP (I have 2) - $150.00 each
All of these prices are without shipping and are OBO. Thanks for Looking.
under construction
Jamestown, OH
Updated pricing on what is left:
Complete long block with Turbo, AC Compressor, and Alternator - $800.00
Complete long block without Turbo, AC Compressor, and Alternator - $600.00
Turbo - $200.00
AC Compressor - $50.00
Alternator - $25.00
vcassens
Godfrey,il
Do you have the intake tube that goes from the cast piece that the crank case vent hooks into and goes to the intake box.
under construction
Jamestown, OH
It did not have a lot of blow by when it was pulled. I however did not get compression numbers on it before the injectors were pulled and sold. I had saved this motor as a spare and was going to put it in the truck when I still had the 1997. It has been out of the truck and sitting for about 2 years (inside of course).
