97 psd white smoke/Hazz always
mcdaniel1991
Germany
A local guy is convinced it's injector cups. But that doesn't seem right to me because the coolant is clean and we're not losing any coolant. And we're not making or loosing oil.
mcdaniel1991
Germany
Well we tested the idm plug and all the test came back within range. We ran another buzz test and the whole odd bank and idm is coming back failed even though they all buzz. We're going to try a different idm and see if that fixes the issue but I'm starting to think the smoke is blueish and it might be a turbo seal.
mcdaniel1991
Germany
Well we picked up a turbo rebuild kit. Going to get it rebuilt and will report back.
benjamindurtka
I soaked mine for a few days and I broke a wrench on one of the bolts on the exhaust side after it was out. Cooked in there pretty damn good.
Sent from my E6782 using Tapatalk
joe d
monroe mi
If you can fit go from passenger side up under truck threw trans tunnel take down pipe out and losen the two pedistole bolts in the back i cut a. wrenchGood six poiny wrench in half to make it fit... Then pull whole assembly out as one and work on it on the bench. Best of luck
rsater1
FLA
^^^^ I SECOND pb blaster 2 days earlier ,, 1 tap from 3/8 12" extension
