99 ext cab shrt bed 7.3 new eng. Built
99-Resurrection
Russiaville In.
99 ext cab shrt bed 7.3 248.. Miles but less than 3000 on fresh engine build... Truck is clean but not perfect.. Engine built by Wagner per. Donor block H11 studs, forged rods, moly pistons, swamps injectors, ts 6 chip. New glow plugs.. 3500.00 plus in long block alone. New Terra grapplers aftermarket wheels.. Front brush bar with 4 Hellas 05 headlight con. Recon led tails led cabs clear lenses putco stainless boards w LEDs 6" black single stack... No longer has 38r but all other in sig is true
The bad noticing a oil leak poss high press line. And transmission has got a high press leak in reverse.... Trucks NOT perfect but damn good truck..only rust on whole truck is typical pinch rust inside bottom of doors
Like to get 9000.00 reasonable offers considered.. May even throw in set of spare old 7.3 heads and fact painted wheels
Kevin Smith 765-491-7725
