A lot of white unburnt fuel smoke when cold
What happened to your truck when the chip was in your buddies truck? Did you run it with NO tuning?
Justin@DP-Tuner
I have had an inline electronic boost fooler hooked to it for about 7 years.
I would try removing that. I have seen the electronic ones do some funky things. The mechanical regulators are much better.
I have tried 3 different CPS. Someone said there is a crank sensor. Is that true?
Nope, no crank sensor. Make sure you are using a Ford or International CPS.
I've never heard of them. Imo it's a tuning or injector issue.
Since he put the chip and injectors into another truck and it does not experience the same issue, I doubt it is a problem with the tuning or injectors.
uncool
California
Have you ran your truck with no chip at all installed? Truck will still run the single shot injectors. If it still does it, I would look for a cracked injector cup.
