? about differential yolks
vcassens
Godfrey,il
Can anyone tell me if there is a difference between the yoke on the output shaft of the transfer case between a F350 and a F450? I know there is a difference with the drive shaft end that bolts to it because of the difference in U-Joint size but I am wondering if they mount to the transfer case with the same bolts. Not sure if it is called a yoke or just a flange but it is the flat plate that the drive shaft bolts to not the slip yoke Thanks
