mudslinger02
Well it seems like its 1 thing after another with this damn truck. I put it on the scanner the other day to run a buzz and CCT and I got a few codes.
P0500 Vehicle Speed Sensor "A"
B1881 Seatbelt Passenger Pretensioner Open Circuit
Im assuming P0500 is the sensor in the rear diff but I only have a problem with it not working when the truck has been sitting outside for a few hours when its below 15-20deg (it normally sits in a heated garage). I wanted to see if anyone else has had the sensor mess up only when its that cold before I replace it.
As far as the B1881 goes, it is very random. Once in a great while the airbag light in the gauge cluster will flash a few times then stay solid. This 1 has me lost. Anyone have any suggestions? Thanks guys!!
