78f100
I just finished a stud job on a 06 6.0 fired it up this morning all was well till I tried to back it out of the shop. The brake pedal is hard as a rock only travels about 1/2 inch and stops. I disconnected the lines from the master cyl to the abs module and bled the fluid there and get full pedal travel. I am not getting any fluid out of the three line going out to the calipers. I tried the abs bleeding procedure with ids several times with no luck. Its like the module is stuck closed. Anyone ever had this happen? I have removed lots of cabs but this is a first for me.
