Im looking to upgrade my injectors but Im not a 100% sure size to with. I Currently have an Adrenaline pump, 38R turbo, bellowed up pipes, and an Air dog fuel system and Id like to know what size injectors would work best. Thanks!
I had your setup with 250/200 and a h2 turbo tunes from TW And love it good mpgs towed super by far my favorite set up by far. Loved it. Take it from a guy that started with 160/100 just start with a bigger injector than you need tune them down. And go from there..
Had that set up for about 80,000 with no problem at all.Don't do this... Unless of course you love working on your truck all the time, adding more mods and killing reliability.
Now I have 350/200 GTX4294R and tow no problems.. just my opinion....
Its all in the turn my man.. my tow then only made 389 on the dyno and egt stayed at 1200 ish towing over 15k
For a play truck it doesnt matter. For a guy that uses his truck, 160/100 is all the injector you will ever need. A 160/100 will dyno 430 or so with a 38R. towing will be fine, EGT's will be fine, factory fuel system will be fine...
You can give it to your son or daughter, or let a coworker drive it and it will not come back in pieces.
Been doing this for a long time, every time I see someone that runs large injectors in a DD... There always picking up pieces, or they quickly sell it and move on to a 6.0 or 6.4...
