AE Help
squeak12
GA
I just got my AE in the mail and ran a few tests to see what I can learn with this software. Anyone see anything worth mentioning in any of these screenshots? I literally just ran them, so I haven't had a chance yet to see what all of these codes, indicate. Also, is there a write up somewhere on buzz testing? I will search eventually, but if someone has something on hand, it would be appreciated.
EDIT: Im going to work on fixing the tiny writing
Tom S
My tip for AE is to look at the values on a cold engine that has been sitting at a stable temperature but not yet started. Does the value for EOT and Intake temp look right. The values for EBPV, MAP, and Baro should be reading around 14.7 at sea level less at altitude. Does the ICP value come up reasonable close to zero.
For buzz just pull down to find it lke you found KOEO. Listen and see if they all sound similar as well as checking the results.
