stroker 6.4
- Joined
- Jul 2, 2013
- Messages
- 146
- Reaction score
- 0
My built is goin to be around 950-1000whp, are any of you high hp guys having problems with axles and what brands are you guys having luck with?
Groomzy don't you have a pullin truck to be workin on?
No to busy getting text from some local d!ldo about what to do to his 6.4
Rcv makes 300m shafts for the sterling, which have worked so far for Erik C., but the comparison against the Dana 80 pinion speaks for itself. Maybe the reason Erik's hrs lived so long is because of his 4.30:1 ratio. BTW, it's always a good idea to weld the axle tubes solidly to the carrier.
Im not sure if Eriks ratio has anything to do with it. The truck doesnt really get abused much. I think if it saw 10 sled pulls, it would kill quite a few components. His truck has been driven aggressively, but I dont think its seen to much extreme stress over the years.
That seems to be the killer, then again, I cleaned off my first 4.10 ford pinion the first time i drove the truck out of the shop and hooked it.
OP, will you be drag racing or pulling more?
Jared
