aftermarket or home made grilles?
Pstroke96
Connecticut
im looking to change up the front of my truck. its been the same for a while now LOL what do you have for different grilles? other than billet grilles. i dont like the way they look
Pstroke96
Connecticut
this is what i have now,
i saw a thread somewhere about a diy rbp style grille but i cant find it now..
Yodersstrokin96
Alvada, Ohio
i used a cut off wheel, a drill and rivots lol just find an old grill and cut out the center then cut metal to fit behind and drill and attatch an wal-ah
FordDZLMan
Victor Idaho
I like how these homemade "RBP style" ones look but if you wanted how could you put a Ford oval or International diamond on one? Plus I'd want to put lights behind it.
Yodersstrokin96
Alvada, Ohio
i think i would make a "mounting plate" that works with you grill and holepattern with just sme thin sheet metal the size of your emblem. st use double stick tape to put emblem on the "plate"
Pstroke96
Connecticut
the ford oval has studs on the back of it stick it through the grille, put some washers on it then the tin nuts back on
