airdog II for 6.0
bboteler
Virginia
Looking for an airdog for a 6.0 with all necessary hardware, wiring and hoses...or another complete setup for a 6.0 at a reasonable price. Time to upgrade the fuel setup.
Wayne
Twin Falls, Idaho
You may consider other options with a larger motor. A penny saved is great until the motor burns up, and you're worse off than before you started. I know a few companies here offer upgrades with fuelab and aeromotive pumps. The higher pressure required by a 6.0 has caused reliability issues for 6.0's and 7.3's. I love my airdog for my 6.4, but it only makes 9 psi.
Derkperk
Twin cities
I run an ADII and haven't had any issues,(knock on wood) but a lot of guys have.
Like Wayne says the 60 psi is hard for those things to do. You may want to seriously look into the fuelab or aeromotive. Longevity is worth the couple hundo.
bboteler
Virginia
ok guys i'll look a little deeper into it, my intentions were to sump feed a 6.4 HCFM to a AD II. But i'm still in the planning stages.
01PSD
Smithfield, NC
You could either:
1. Buy or make your own custom setup using an Aeromotive/Fuelab pump
2. Use a 6.4 pump to feed the stock 6.0 pump
3. Use the 6.7 low pressure pump as a standalone setup.
I think any of those setups would work well.
Wayne
Twin Falls, Idaho
The worst part about the stock fuel lines is the inside diameter of a lot of connections. Several of them are only about 3/16" i.d. try and support 600 hp on 3/16" supply LOL
java
Texas
My second AD2 took a dump on me so I ordered a fuelab pump with new bases and filters. I wouldn't recommend an AD2 to anyone.
bboteler
Virginia
I have a line one a 6.4 setup...maybe i'll keep it simple, sump to 6.4 to stock 6.0 see how things look...I'm no where near 600, seeing other similar setups i think i'm 500ish. but that's just guessing.
FP isn't dropping below 65 at wot now, but I'm thinking of adding some insurance to keep from having to spend big $$ later. hence the post here. I really appreciate all the input guys.
Building my own setup isn't out of the ? but i can't bring myself to completely throw out what working now the more I think about it. If it dies it's a completely different story.
