Airplane project inside
Snake
Flo Rida
Diesel ain't gonna fly. Pun intended.
My father in law built a Kitfox tail dragger in his garage years ago and is an IP. He sold the plane a while back but is still crazy smart on this kind of stuff.
MINK
London,OH
I predict this project will never get off the ground.
:D
Powerstroked162
On Da Juice
Wa. State
Guys, lets try to not muck this thread up with gay pics(mink) and useless posts. A 7.3 in a plane is totally do-able. No reason why it won't happen
JD3020
Farmersville/Dayton, Oh
I agree, its totally do-able. I could even drop 2 7.3's in a 172 if i wanted to. But would the plane hold up to the weight and still fly properly? Hell no it wouldn't.
Now on a serious note i was flipping through Flying magazine a month or two back and ran across an article on the future of diesels, and it sounds pretty promising. Just seems like the main issue is weight, even with smaller engines.
Snake
Flo Rida
Wait. Are you talking about making a dirigible? A Zepplin? Cause that would work. LOL LOL
Charles
Something like this would probably be more receptive to a heavier engine package:
As for actually flying.... good luck with legality with it being experimental and all.
The power to weight ratio is struggling hard on a 7.3 for the air. Continuous power would probably need to be in the 1000hp range to support that engine, and it's simply not going to happen. Not even close.
Best case might be simply the ability to get off the ground and land again without melting a piston or splattering yourself across the ground if this was attempted in something like a Cessna.
Powerstroked162
On Da Juice
Wa. State
I think we would have to address props first probably. The sheer torque and power of the 7.3 would most likely disintegrate the prop hub on start up. It would probably have to be some type of hardened alloy, maybe even miraging material to ensure durability.
Viking
Minnesota
adamantium?
JoeDaddy
Gridley Ks
Zmann
Hmm I suggest a basement build
IIRC that's how Mike Rowe became popular?
powerSmokin
Marysville, Wa
A few things to consider would be:
What range to most cessnas run (RPM wise)
How cold will the engine get when going to the higher altitudes
Burn rate of ruel, there is a reason why Jet Fuel is used in planes
Weight ratio and the center line of the engine compared to the whole plane
Will it be FAA approved?
Amount of torque at the prop but yet maintaining the right amount of speed to the prop.
Electronics obviously
Also the durability of the engine compartment (will it hold the weight without damaging the hull) going up and down along with turbulance is alot of stress for that small of a plane.
