Stock would probably spool it, but I would go with 60's and pull some fuel out of it. Then in the future if/when you want to step up your air, all you have to do is bump up the pulse width. Then your not buying nozzles twice. I would also have you injectors flowed and balanced. Jared at RCD can hook you up.
i need some imput how would a s467 spool on a stock fuel 373 gears on 37s ?? canadian dollar is low as hell to expensive to buy out of the states at the moment thanks and weres the guy selling high power in alberta ?????
