Another PMR hp question
02BigD
Coastal NC
Having run 30, 80, 100, and 200% nozzles on various sized hybrids over the past 8 yrs, the 200's are the coolest and cleanest by far. On the downside, going from 100 to 200's I have lost some mpg's but I wouldn't trade the extra 75ish hp back.
On edit; as much as Curtis drives me nuts with politics, the guy knows PMR tuning and he's been very gracious in many threads sharing that knowledge.
CurtisF
You are correct with a tow tune 350 is where you would be. BUT how much fuel do you think you are really injecting in your scenario? No where near the. 250cc. Promise. The difference is with the 175's you still mostly get the. 175 even while towing. It's all in how it comes in. The 250's prolly less than. 200cc. And depending on the brand way under 200. I have seen 250's that under normal conditions seen in everyday driving a bench flow test reveled any where from. 125-195 max output. Yet they are sold and marketed as. 250.
Start with this statement right here.
Simplified version, at 1 rpm you have a huge window to inject fuel. At say 3000 rpm a much, much smaller window to inject fuel.
This is how you spec an injector. Find what you want to do with your truck. Example #1 - Heavy Tow. Spend majority of your time at lower RPM band? select a 30% nozzle because it CAN move a good amount of fuel, yet make for a nice clean burn. 160cc of fuel can easily make in the mid-high 300HP. Perfect for towing and maintaining nice cool EGT's.
Example #2 - sled pulling. Spend majority of your time at higher RPM band? select 400% nozzle because it WILL move a lot of fuel, nothing else matters. 300cc of fuel can easily make in anywhere from 650-850HP depending upon the setup. Anything more that much over 300cc will not inject within the RPM band a lot of pullers are trying to be in. That takes you back to the whole theory of why have 1000cc injector if you can only inject 100cc.
Now you have to also throw into this equation that you really have a set of injectors that REALLY do inject what they claim in a realistic usable time frame.
And then you have to have a tune that is capable of making use of the fuel that is available.
We're on the same page with injection window. And yes on a PMR motor you aren't using all that much fuel, especially on a bigger injector (i.e. 250cc's, 300cc's, 400cc's, etc). But forget what the injector CC's are claimed to be, and I'm not even starting a pissing contest with vendors about who can more accurately pinpoint their specs. None of that matters unless you are really and truly trying to squeeze out every drop of fuel that they are capable of trying to win a drag race or sled pull. This thread isn't about that. It's about making as much useable power as you can without windowing the block. That won't happen until you focus specifically on what I've already said: amount of fuel injected at a specific time and specific duration.
The amount of fuel available and amount of fuel injected are two completely different things. The point when the amount of fuel available becomes a problem is when you don't have enough available to begin with, and you try to get the tuning to squeeze out every last drop to reach your power goal. So if you want 450hp on a PMR motor and you want to achieve it with a 160cc injector, you'd better rethink your build here, because you aren't reaching that 450hp mark. If you come close to 400hp on a 160cc injector, you aren't doing it efficiently enough to make that power useable in the first place.
So you go with an injector that is capable of more in order make that power possible, and to make it useable. Time and time again on this forum people say they want "X" horsepower, and time and time again the response is to suggest an injector that will juuuuuuuuuuust baaaaaarely get you there. Ok fine, but can you actually use that peak HP reliably? The answer is no.
The other part of the equation is the nozzle size. Again, don't pick nozzles that will juuuuuuuuuuust baaaaaarely get you there. Pick nozzles that will make it easy to reach the power goal. That way you or your tuner have more flexibility in that injection window. But it has to be a careful decision, because like I mentioned already, larger nozzles can be more of a bear to get dialed in. But if you have teeny weenie nozzles to begin with, you've already choked yourself down to a lower useable power limit, and immediately limited what can be accomplished. A longer duration as that injection window shrinks will always equal higher EGT's and more smoke. There's no way around it, and suddenly you reach the tipping point where you no longer have useable and reliable power. That's when you see people reach for band-aids. For example, when I see someone running 160cc injectors and water injection, I immediately see they chose the wrong injector and nozzle size in the first place.
In short, get an injector that can easily reach your goal, and one that you can live with as a daily driver. The rest is entirely up to the tuning to achieve it..... and keep the motor alive and happy.
CurtisF
Myself, including a few friends all ran 38r's on our PMR setups with 250/100's. And with that said we also all broke rods eventually. Mine ran for 40k miles before it let go. Others weren't so lucky.
And that's all in the tuning.
For perspective, 250/100's can be tuned to run less fuel than a stock injector. If you have less fuel and have the timing pulled back, you aren't introducing any more stress to the rods, so you aren't going to break them.
In other words, it's not the injector. It goes back to how much fuel injected at what time and duration. Those rods broke because it was too much at the wrong time.
Now before this turns south....... do you go and blame the tuner? Not exactly. There are customers who do ask to push to the limit, and when you do that the result is you will find said limit from time to time.
But at other times there are tunes out there that really do have the wrong amount of fuel at the wrong time. A good conversation with your tuner of choice is key before they ever start touching the keyboard and build your tunes.
If I could do it all over again, I'd go with a 200% nozzle. The way I understand it is a 200% nozzle empties faster thus making the injection event faster and thus lowering cylinder pressure.
Not exactly. I'll clarify so you can see what's going on.
Larger nozzles empty faster, giving you or your tuner more flexibility over the injection duration. This is important as RPM's climb and your injection window gets smaller and smaller.
It doesn't lower your cylinder pressure. It just gives you flexibility to keep it a bit lower as your power demands increase. Because you have more fuel available at higher RPM's, you can shift your power band up in the RPM spectrum. As I mentioned before, torque can be a good indicator of your cylinder pressures. You absolutely must have higher cylinder pressures in order to achieve higher torque numbers at lower RPM's.
So, limit the fuel at lower RPM's. You have now lowered your torque number and cylinder pressures. On the flip side, with a larger nozzle you can now add fuel at higher RPM's. This increases your horsepower number.
My best example I saw in person was when I strapped my truck on the dyno at an event a few years ago. Another guy there had a truck with 238/100's. He made 1hp more than I did, but well over 100 lb/ft of torque than my truck put down. Our trucks were nearly identical except for the injectors. So in the end I essentially made the same horsepower, but with lower cylinder pressures and a shifted power curve that brought in more fuel at higher RPM's.
Does that make sense? I tend to get a bit wordy but hopefully clear enough.
CurtisF
Maybe you would be willing to post a couple off video again, curtis, of your idle? :toast:
Here's some old videos, and I've been too lazy to take new ones. Plus I was playing around with some timing stuff on my tunes, pulled timing waaaaaaaaaaaay back, slapped the tunes on my chip, and then my burner broke. So I've been stuck with these hazing tunes for the last 6 months and I'm a cheapskate who hasn't bought another burner yet. I might just cut my losses and go with a Hydra. That will make things more convenient for tuning.
Ok enough of the side track....
Old idle video Not quite dialed in, but then again I've never had it perfect.
http://youtu.be/eNnIzdOYUSs
0-60 something acceleration test.
http://youtu.be/nNFFSyyTReI
David N
Eastern NC
You're a smart man Curtis, no doubt in my mind.
And there was no bashing of who tuned my truck. Matt tuned it from day 1, and I always pushed my truck. It never came off the hottest tune and the one time it did, it blew up literally 200 miles later. Coincidence? I'll never know.
Matt can tune anyone's truck to safe levels with pmr's. I just wouldn't expect anywhere close to 500hp though. I was one who didn't care if it blew, so I wanted all the power I could get. And I was 100% satisfied. I still recommend Matt.
ja_cain
*Stupid Question Alert*
When you guys refer to more timing do you mean when precisely the injection event is initiated relative to tdc?
CurtisF
Yes.
In the simplest of terms, Start of Injection (SOI) is when the injector opens up and sprays fuel.
Now there is a lag time between when the event is "initiated" and when it actually does spray the fuel. That is accounted for in the tuning. There is also another lag time between when the fuel is sprayed and when combustion actually takes place. That varies based on different parameters. For instance, higher injection pressure causes greater atomization of the fuel, and it ignites quicker than fuel injected at lower pressures.
It's a fun game. :fustrate:
238/100s should put you in the 500+ hp range, Jonathon (currently Dyno-proven who wrote and am asumming beans still sells his tunes) got 490 something HP just out of 175/80s
dyno or track hp numbers?
Not going to quote Curtis' long post. But you better listen to him.
Sent from my truck while eating, adjusting the radio and passing a Mustang sideways.
what he said^^^
Chvyrkr
Threads like this are why I hardly ever post anymore.
All I'll add, is I ran a PMR engine in a pickup that trap speed said was making 420hp, for 30k. The undamaged long block came out at 236k, and is sittin in my shop.
Never came out of the hot tune, and towed up to 12k with it. Rev limiter set at 4k RPM's, and verified.
If a good tuner live tunes a PMR motor, your chances are just as good as a forged motor. Sub 500hp.
I didn't start having issues with engines until I swapped that PMR engine out. If I could do it all over again, I'd still be running a low 400 on the factory installed PMR engine.
a11m1ghty
It doesn't matter what injector. You can run 400/400's on PMR's. Never mind the max hp that an injector is capable of. Everyone just get that out of your collective heads and throw it out the window when it comes to PMR tuning. The idea of "this particular injector is capable of X amount of horsepower". Toss it away.
What matters is how much fuel at what time and duration. That will be mainly up to your tuner, and partly what you want him to do. The injectors you choose will determine what your tuner has to work with. After that it's supporting mods being able to make the power time and time again with good performance and manageable EGT's.
First, stop looking at horsepower. Look at torque and set a limit. For PMR's, make it under 900 lb/ft if you want it to live as long as possible. Go higher and good luck, you're going to need it.
Why torque? Because that's your best indication of cylinder pressure without having an actual tool to measure the cylinder pressure in real time. High cylinder pressure is what is going to pop a rod, and PMR's just love to jump out of the block when cylinder pressures spike. You can have 400 hp and 1200 lb/ft of torque, or you can have 500 hp and 900 lb/ft of torque. Which one has the higher cylinder pressure? I bet you can guess at this point.
As for the injectors, larger nozzles will give you more horsepower with less torque, because they have a smaller injection window that they can work with and you can continue to make good power at higher RPM's while keeping EGT's nice and low. But at the same time they are harder to tune for many, and require some refinements to achieve a nice daily driver that you are truly happy with. On the flip side smaller nozzles are easier to work with in regards to making your truck a pleasant daily driver, but require a much longer injection event duration. This longer injection event can increase EGT's and limits your upper RPM power as that injection window shrinks.
Pick a tuner you are comfortable with and talk to him about your goals and what components you plan to toss under the hood. The two of you will be working close together until that truck is running as you want it, so both of you better be speaking the same language before you open your wallet.
Is this going to push the limits of the PMR's. Uhhhhhhhhh, yeah. Of course. You're going to gamble, just know that here and now. Understand what can possibly happen, prepare yourself for it, and don't be surprised if it happens.
For my own truck I've been very happy with it. The thing is a work beast and nothing out tows it up a mountain pass. Period. It's been alive in it's current configuration and power level for several years and tons of miles, and it hasn't skipped a beat. Knock on wood it keeps this up for many many years to come.
*Your experience may differ.
Old thread, but need direction.
I just found out yesterday after confidently "knowing" that my 05/01 build date was going to net my 01' Excursion Forged rods. Well yesterday, I was sadly mistaken as I viewed through that "portal of truth" port next to the oil filter.
There went my dreams of 1000+ ft lbs of torque, lol.
With that being said, what mods to your 7.3 have netted you under that safe realm for ff TQ for your PMR's (Your HP/TQ #'s in your sig sound great!)?
Thanks!
Unbeknownst member of the PMR club
-L
Thanks!
-L
You can still have those dreams. It just taked good tuning to get it there.
dsberman94
Pennsylvania
Lot of live and dyno tuning. Engine I have now is factory forged rods and I’d bet I’m over what everyone says they’re rated for. But the low rpm tuning seems spot on.
thuglike
Linden, NJ
This.....
Plus I'll add.....if your going for 1000...I don't care what rods you run. At that point you better be prepared to make an offering to the scrap metal gods. If you're not....stay around 500 and have fun. 5-600 is fun.
Either way...good luck
This.....
Hey thuggy! Still around i see. Good deal!!
Lt.Dan
Visalia, CA
This.....
I think he means 1000ft/lbs, which with forged rods I think is very doable.
1000hp is another story lol
Chvyrkr
Who the f__K is still tuning for torque?
To the guy asking the question, I ran over 30,000 hard miles on a PMR block that consistently trapped in the 420 range for HP. On the dyno it was in the 90% powerband from about 2400 to 3800 RPM's. Truck never came out of the hot tune, towing, playing, etc. That complete and healthy longblock is sitting on the floor next to a 58 ford. Maybe someday I'll have time again...
Put whatever you want on it, and then tell your tuner to account for the PMR's. The guy that tuned mine isn't tuning anymore, but there are still some great dudes playing with these.
I didn't have engine problems until I went to a forged block... And that was aaaallllllll my fault.
