Another rad...
08stroker350
Rad is leaking is the same spot. Will be installing another Ford one under warranty. Has anyone found a way to keep these things alive for more than 2 years :doh:
replace the cab mounts with OEM
Black AOD
Ohio
Replace cab mounts.
Try a V2 mishi. I hear no complaints so far about the V2
fubolislif22
how hard is it to change out the oem cab mounts, I do not have this radiator issue (knock on wood), but when and if the time comes I would definitely want to change out the mounts and radiator with the v2. Just curious on the replacement process.
I hear the mounts are about $400-500?
Hope you solve your issue!
