Whiplash16
- Joined
- Jan 28, 2015
- Messages
- 15
- Reaction score
- 0
Searched countless hours on the forums and tried lots of thing with no luck. E99
Mods are-
CAI, 4" exhaust, unlimited diesel 160cc single shots 0%, 02 turbo with ww and banks housing with banks WG, new valve springs, riffraff crossover, running tunes from gearhead, rebuilt trans.
When its cold it seems okay or better but when its warmed up the truck will shake. Not real bad but enough to be annoying. It will also chug at 35 mph and 1100 rpm.
Things I have changed in this long quest are-
New IPR, swapped icp with no oil in either connector, swapped in a swamps idm but prior to a new test tune I have now do to hpo being a little low. New ebp tube and cleaned sensor. Gray cps, and new uvch. Pulled injectors again and had them checked. Supposedly checked out fine.
The truck seems kind of smokey to me but otherwise runs good. Hits 28lbs boost and never seen the egt over 1200.
Fuel pressure seemed to be an issue. Was at 72 and changed the spring to get down to 65 and it run slightly better.
When it chugs the hpo will fluctuate up and down. Not sure what fuel pressure does at that time tho. New front main seal, I however did not take it of but the lpop looked okay and I don't see how I could have put it on wrong beings it has good pressure. Rebuilt oil cooler also.
I think I am getting air from the tank but it will do this even with a full tank, I also put a hose from the fuel pump into a jug to ensure I'm not getting air with no luck.
Another issue is that a couple times I've went to start it she will just crank and no start, cycle the key and starts up with a cloud of white smoke. Mpg seems low also. Getting 14 driving like normal.
If anyone could help that would be great. I'm willing to try anything but not sure what's left to try anymore...and thanks for reading my novel.
Mods are-
