...or go with compounds!
Tuning is definitely important, especially the bigger the nozzle, but how do you tune to make a turbo move more air at 2000rpm with out raising the EGTs?
Run a iarger nozzle and pull pw until the icp is out ahead of the pw for starters.
I wish someone that had Charlies # would alert him to this thread. Hes had compounds and 400/400s, and 300/300s, and 250/200s, and 200/30s etc etc etc. He is running 300/200s and a 38r on a BONE STOCK truck. A pmr to boot and is surging the turbo in od at 50mph towing and BUILDING BOOST UP HILLS. But you guys are saying 175/80s and other ridiculous crap is too much for a 38r.
I understand the whole "doesnt flow shti" thought process about the 38r. Ok, on paper its not where some (define who these people are and ask them "wtf do you know?") arbitrarily decided what this turbo should do. The issue with that is 90% of the time you arent in demand of the flow it has anyway.
Tarm and Tim both hit upon the issue. TUning. Ive had dogshti tunes with a setup similar to mine even on the same truck and it was approaching 1k deg cruising at 75 with 37" tires. I called my tuner. He berated me and said i had a mechanical problem. I called good ole Bill Cohron and explained my issue and at his behest i was to try to make it right with my tuner. Ok. Phone call. More assholio bs and I called Bill back "im sending you this chip with xyz's tunes on it. They suck. Hot as hell."
He calls me a week later "hey these tunes are garbage. Waaaay to much fuel here, here, here and here." I interrupted, "please write me new tunes!" Done. Guess what? My "mechanical problem" vanished. My compression must have magically bumped up.
I am able to scrub the tires in my economy tune from 0-20...thats like the most neutered tune there is lol. I did a 0-100 in that tonight and it never broke 1k degrees. SUnday night i timed my 40-90 to simulate a heavy acceleration merging scenario and in 5.2 seconds in my "economy" tune the truck slingshotted from 40-90 mph and egts hit 810 and i let out. FInd me an ad truck with a 38r and a race tune that can hit 100mph on 35s and under 1200 degrees and ill kiss your azzes.
Im expeditiously scouring my photobucket for the picture I sent Bill two summers ago when i was forced to run my ad codes with 200+ on them and a 30% nozzle with my 38r while pulling 16k worth of **** on a 26' trailer up a grade for 7 miles. I was able to maintain 60mph and in a "40hp heavy tow" that had transmission adjustments tow that load up that grade and i was in between 7 and 800 degrees.
