Another tune question.
SpyderX
Boaz, Alabama
Getting the SCT X4 with *** Deleeet as mentioned. Is it necessary to get the EGT sensor? This keeps an eye on exhaust temps, is that a concern with tuning and Deleeting? I thought doing these Mods would reduce engine temps..
GregW
KY
It's always important to monitor vitals like EGT. Pulling a trailer up a long grade, things can start to get hot pretty quick.
SpyderX
Boaz, Alabama
I see. So I guess I should get the EGT kit then when I place my order.
brown1
southern michigan
to bump an old thread, the stock sensor is still used yes? what is the purpose of the aux one and if the stock one is installed where would the tuner one go?
8WR_ZJ
Can the X4 read the factory egt sensor from the exhaust? If so can remove the factory sensor and place it in the egr plate and still get the temperature to display on the x4? Much like that on the mini max, Spartin and ez lynk?
TLyons90
Greenville, SC
I could be wrong and not looking correctly but according to my X4 hooked up on my truck. I see no reading or PID for EGT.
Kenz
X4 can read EGTs. You need the SCT probe, the factory one won't work. To read EGTs use the analog in 7.
