Any 05-07 trucks running 4400#coils.
Vader's Fury
Chesapeake City, MD
Looking for a couple of measurements from the front suspension if anyone is willing to take a few.
Need the height of the spring at ride height.
Also looking for the distance from the axle to the frame at ride height.
Also curious what you are running for rear springs? No block? Any leafs removed?
Looking to go to 4400# springs on my Excursion when I do the suspension swap, but I want to try a hydraulic bump stop. Just need to see where I will have the room to install one.
Halestorm55
Skiatook, OK
With 08-10 leaf swap and no overload the spring perch would be 5-5 1/2" from the frame. Mine is at 5 1/4" with a bed box and about 400lbs in the bed I measured to the top of the lift block. 08+ was the same height with the overload in as stock leafs were.
Vader's Fury
Chesapeake City, MD
Thanks, That helps for the rear, but was looking for front suspension measurements. Trying to figure out what options I have for a bump stop in the front.
