Anybody elses truck sound like it falling apart over bumps?
treatcg
My dash sounds like it is falling apart in my 2016. Lots of squeaks and rattles in between the storage area and windshield on the dash.
Jomax
Arizona
I have none of that.
ckrueg
Belding MI
Same. Compared to my 2010, my 2016 has a lot less rattles and that truck has a straight pipe so there's 3 times the engine noise.
04cr450
harford county, maryland
only issue i had with my truck is a vibration noise, pretty bad, when idling in drive- was a loose tcm located on drivers side frame rail. Tightened it and good to go.
Jomax
Arizona
Sweet, I always wondered why ford put that there. Seemed so easy to destroy.
04cr450
I wondered myself as well.. dupid ford..... I can also why it vibrated so bad , the bracket only holds onto the end of the module. Even when the bracket was tightend the module will still move up and down.
300000 and counting
Ohio
I used tubing on my last truck, it was a sclb and there was a part of my factory striping that was blocked off. What did you guys do when you came to the blocked off part?
vansnxtweek
I feel really stupid but I cannot find where these strikers are to put tape around. Where are they?
chaselee
Here
bpan
Don't loosen the strikers, just give them a good whack with a punch and hammer. That worked wonders for me.
Semi-retired
The rattling and clunking on my 11 comes from the under the truck and sounds like it's in the suspension. It sounds like the truck is falling apart even though it only has 30,000 miles
marserdesigns
Damn I thought my truck was the only one!! I took it to the dealer 2 times and they couldn't find any thing wrong! Sure glad I found this thread!!!
Mine is coming from the drivers and rear drivers side...sounds like my doors are barely latched. I constantly open and close them to ensure a good close. My only thing is I paid a lot of money for my truck and less than a year later it sounds like it's falling apart.
so you are just trying to bend them in a hair? my strikers have self centering bolts so it can't move..
bpan
If you hit it hard enough they move in ever so slightly. But if you loosen the bolts and re tighten they will re center.
