Morgan@Midwest Diesel & Auto
So what was the overall peak tourque and where was it on the graph? I dont see the second torque numbers on the graph. Just curious if the torque was slower to come up too?
What the graphs show is slower spool up with basically lower hp up to the point of intersection. The lines intersect basically at peak hp level when they are equal. all other numbers are lower across the sweep with the steed speeds. The 131ft lbs is interesting though. Did you happen to data log boost and pyro numbers?
You can't really say that there is no pay out. He did claim to have more torque. There was probably lower egt's as well. The problem is that the power is slower to come in, which for street driving makes the 131ft lbs a moot point when you have to stab the throttle harder to get it! This design may actually make more power for a pulling truck where spooling speed is not important and all out high rpm performance is key. They may work well with a big single and 4500-5000rpm. But unless someone with that setup is able to dyno and compare, we will never know.
Glad you cleared that up! It wasn't making any sense to me with the previous chart.
I'm picking the new manifolds up today. Tests to be done quickly I hope.
