Anyone running batmowheels?
Bignbadbelair
Hey guys are any of you guys out there running batmowheels? If so was it worth it or no? Also I heard you can take and get your intake housing machined out and install a 71batmowheel in. Is that true? I heard some good things and also some bad things about batmowheels what are you guys suggestions? If not a then what turbo combination do you guys recomend?
6.4strokin
I wouldn't run batmowheels. Pick up a 71mm or 72mm direct drop in low pressure atmo turbo
B585Ford
WV
:whs: As far as brand goes, we all have some bias but I would go with Barder, Elite, or RCD
