Fly By Night
My gpr went out so I was jumping it with a screwdriver as needed. One morning I couldn't find a screw driver so I thew the only thing I could find in there, a half inch drive ratchet. It fell over shorted and welded itself to the bracket for the plastic engine cover. When this happened I saw sparks come out of the passenger side fender area i believe out of the starter relay. I had to grab something else out of the truck to break the ratchet free. After this my charging system quit working and I don't get power to the gpr. Is there some sort of fuseable link or something that feeds the gpr? As for the charging problem I took my alternator to Oreilly and had it tested, it failed I swapped in a new one and it still won't charge. I'm not sure what to look for voltage wise from the 2 little signal wires to the alternator.
