lariat 7.3
- Joined
- Dec 2, 2012
- Messages
- 658
- Reaction score
- 0
What are you all's average egts while loaded running about 70? I'm talking 10k +
Like on flats? I see 700-900 on flats usually kiss 1300 once in awhile on grades I'm usually at 25k+
I've run 1000-1100 for hours, like 6 to 10 hrs, before.
If your nervous about egts, have a tune that downshift sooner, let the rpms help!
Like others have said.
Stock you can push them to 1300.
My truck stock working hard pulling a hill it would sit at 1200-1250 all the time. That's not excessive.
I would start backing out of it at 1300 thou. Perfectly safe.
You mean you can work a diesel engine? :shocked:
I run around at all sorts of weight, generally 18-22k GVW. 250/200%'s, non-intercooled, stock OBS turbo, one up-pipe isn't even bolted to the turbine collector, 4.10 gears. Tune it myself.
Taking off from a stop it'll usually peak around 12-1300, cruises around 1k. Hills it'll run 14-1600 depending on how hard i wanna push it. Last summer i was racing my brother up a decent sized hill on the highway. Started the bottom at 60, was doing 70 at the top. Had a 25ft GN and a Cat 304 mini in tow. Pegged the pyro, 40psi, and never looked back. LOL
You have been battling this "egt issue" for almost 2 years now. Why have you not fixed this?? It's not hard to do...if chasing boost/exhaust leaks led to nothing, and you have exhausted every option...contact Matt, and have him try re-writing you new tunes that pull more fuel out. Or maybe you need to deal with the fact that your egt will be a little higher when towing modified, and you will have to learn to actually drive the truck. You can't just push on the pedal, and go..and if it starts getting a little warm, think to your self "self, hrmm, well gee golly, my egt is higher than when the truck was stock, or it's close to what I read on the diesel stop, would melt my engine down into a smoldering pile of rubble...this piece of shti must be broke". You stated before you couldn't pull a boat at 65 in od, without high egt's. 35's and 3.73's knock the gearing down too low at that speed to maintain OD, and have enough rpm to keep it cool. Get up over 70, and kick put it in overdrive.
I agree...
I put 4.30 gears in mine and it tows like a dream compared to the 3.73's.
Mine runs 2k rpm's @ 65mph. Plenty of boost when cruising with a loaded trailer, and the egt's rarely ever get out of hand. I tow 20k+ running 70mph often...
Lots of people say 35's and 3.73's are a perfect match. I disagree if your actually gonna pull anything heavy.
There is a difference in "brief peak" and continous duration.
