axles obs and 99-04
psduser1
on the road
I have five axles for sale, two matched sets, and a rear axle. Both sets are srw, 3.73 gears, in serviceable condition. Both set came out of 01 f250s. One set needs hub bearings and vacuum seals for the front. The other set is serviceable as is. Both rear axles are serviceable as is.
Both sets are complete, to include rotors and calipers all around.
700$ for the serviceable set, 500$ for the set that needs bearings.
The single axle is a 95 model, drw, complete from drum to drum, with new brakes (within 5000 miles). This axle also has a maghytec cover on it. Ready to bolt in and run, the truck it was under was in an accident. 200$
All prices are obo, and do not include shipping. Located in 48846 area code.
I am also posting rims/tires in the appropriate forum to match these axles.
I have pictures, but apparently I'm unable to load them at this time, so pm me or text me at five17-20four-5ninenine4, and I can email or text them.
psduser1
on the road
The other srw is under a truck somewhere in the county right now, lol.
PsdPullerJr
Western PA
Measure the length of the pinion. If you know for sure one is a 50 and both are the same length then they are both 50s. I'm thinking about that drw axle you have, how soon you need it gone?
psduser1
on the road
One set of srw, and the obs axle are out and on the ground, ready any time. Sooner the better, lol.
When you say "measure the pinion", do mean housing centerline to the end of the pinion shaft/nut?
I thought the 50 and 60 both had the same case dimensions?
PsdPullerJr
Western PA
Something like this. From the back of the case to about where it "humps" up. A 50 is about 4.5" and a 60 is about 5.5 from we've found.
psduser1
on the road
I measured one, there is a difference as you described, psdpuller. The other one is under the truck, pulling a trailer. Guess which one I wasn't sure about, anyway! It'll be backhopefully around 7 tonight, and I'll check it then.
