Bad 6.4 block, heads
Vader's Fury
Chesapeake City, MD
I need a block and heads for a mock up motor.
I don't care about pistons, cam etc. Just need a block and heads that I can bolt together and set in the frame to lay things out.
If it has a pan and valve covers that would be great but not necessary.
Let me know what you got. Do not want to ship, but willing to travel a limited distance for a good deal.
webb06
Seneca, MO
Where are you? I've got 3 core engines but you might be too far out
Vader's Fury
Chesapeake City, MD
How much external difference (size, shape, pan etc) is there between a 6.0 and a 6.4 long block? Will a intake from a 6.0 fit a 6.4? I have a couple of 6.0 blocks lying around. Might be able to get by for the short term with that.
