Bad IDM?
dthompson
SW Kansas
Ok, working on my Dad's 02 7.3. Guy he sold it to said it needed a motor, so dad bought it back half price. Ended up being 2.5 gallons low on oil, so no ICP. After we got it running it never would start right even after a 300-400 miles. Still started like crap. Does have blowby, but still ran ok. Then last week, it had no power, missing, and died. Now i hooked AE up, and buzz seems to be ok, but then says: Cylinder 7 high to low side open, as well as 3,5,6,8. Also says Injector high side open Bank 2. Is this looking like the IDM took a crap?
2.5 gals low? It'll stop running a gal low.
The motor could be crap now if it was ran without oil.
Im no idm expert so Ill shut up now.
dthompson
SW Kansas
It does have high pressure oil while cranking. I know that the motor needs changed, but ol' dad will drive it till it gives up. Think I might have an IDM that i could swap it out with. Guess I will give that a shot for now.
co04cobra
WV
If it passes buzz test it's probably fine. Sounds more like uvch unplugged. I'd pull valve covers first.
While VCs are off pull compression then you'll know if that's why it was losing oil or injector oring problems.
that too. I didnt catch that it passed buzz test.
co04cobra
WV
If it's partially unplugged it will still buzz. But hard start and both banks does change it. I didn't read all the way through the first post.
TARM
Blowby? enough to blow the oil fill cap off the inlet?
Those high to low opens take in both banks so I can understand looking at the IDM. To me if you have a IDM handy or can borrow one its quicker and easier to swap the IDM than to pull both VC. Not to mention with the IDM connector pulled you can OHM out the entire circuit going from the IDM to each injector and each banks ground. Of course check the outside plug top each VC. Making sure its secure. Here is a link to the procedure ( you need a mulitmeter) http://www.gbreman.com/techbulletin_103.html Takes me about 30 min to get into the wheel well unhook test and close it up but I have done this a few times. It should OHM out ideally 2.8-3.0 but spec is supposedly up to 3.6 ohm. They should be fairly consistent from one injector circuit to the next.
If it does need UVCH harnesses only use Ford or IH.
Also look at the harness where it crossed the driverside VC. It can rub and wear thru and short.
Personally I would pull the IDM connector anyways and test and leave it open after. If it shows you have shorts etc once you have changed out the UVCHs you can then retest and be sure that all the injector circuits are good from inj to idm meaning no wiring issues. Then you can plug it in and rerun the tests and see. If its still got IDM code issues you can swap the IDM to see. Do all of this with closing up the VC either to be sure. That way if its injectors themselves you already have it open.
I hate repeating things over and over again if I do not have to so once something is opened up I try to do all I can before buttoning things up to ensure as best I can that I do not have break it open again for the same issue.
buschpoweredstroker
Upstate NY
You don't have to worry about your motor being junk from running it low on oil... within seconds of losing low pressure oil the engine won't run because you won't have any High pressure oil either to fire the injectors. Kind of like a safety shut off. I have to mention it because no one else has, have you tried a new cam sensor?
dthompson
SW Kansas
Old idm still shows same codes after the test. New one is clean. Buzz is good on all injectors. What am I missing? Motor give up finally? Had enough blow by to bounce the cap and started hard then idled rough before this.
