gnxtc2
Working on a friend's truck, 1996 7.3, auto trans over two days. Unknown mileage as the he bought the truck with a bad mileage odometer. Straightened out a lot of issues but has a bad lope on start up. This is what I replaced with Ford/Motorcraft parts.
Truck is all stock, no tuner; just intake and exhaust.
- Both valvecover gaskets (2) and (4) injector harnesses
- Glow plugs
- Glow plug relay
- (1) Broken rocker
- Fuel line hoses by the fuel bowl
- Resealed fuel bowl
- Replaced vacuum pump
- Fuel filter
- Oil/filter change (15w-40 Motorcraft oil)
When I had the valve covers off, there were four different injector solenoids which relay don't mean anything to a normal person. I myself wounldn't accept that but anyway.....
The bottom of the fuel bowl was loaded with crap. Yanked the fuel bowl and cleaned everything. The screen was loaded up, that was cleaned.
Started the truck after doing the fuel bowl, it loped but I contributed that to empty bowl. Today I start the truck, it fired right up but loped bad and smoothed right out. It sounded exactly like this video I found on YouTube. https://www.youtube.com/watch?v=nxdT-dso-cI
I'm gonna try to start the truck in neutral tomorrow to rule out the transmission range sensor.
Went for a road test; truck feels lazy. Maybe I'm just used to my truck.
Anything else I can check? No CELs set. I haven't put a scanner on the truck yet nor checked fuel pressure, got late.
Billy T.
[email protected]
- Glow plugs
- Glow plug relay
- (1) Broken rocker
- Fuel filter
Billy T.
[email protected]
